Activity Forums Adobe Premiere Pro Interlaced DVDs Using Premiere Pro CS3 and Encore CS4
  • Interlaced DVDs Using Premiere Pro CS3 and Encore CS4
    Posted by Jack Deren on January 26, 2009 at 4:30 pm
    Im having some difficulty achieving 24p output on DVD disc using My GL2 in frame mode. My project settings are 720×480 DV 24p. but maybe im not selecting the right 24p conversion method under the playback settings tab. There are two options there, repeat frame (ABBCD) and interlaced frame (2:3:3:2). Default was interlaced frame and is what I had kept selected.
    Another possibility might be that I did not select the correct field option for the clips. But I dont understand why I would have to change that since the footage was already progressive (shot in frame mode).
    *Mind you, the project in Premiere does not appear to be interlaced at all and looks great in the Program and Source monitors!
    Therefore, should I have adjusted something in the field options? OR
    should I adjust my playback settings?
    Please help, this problem is driving me nuts!!
    Jack.
    Jack Deren replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
