Activity › Forums › Apple Final Cut Pro Legacy › interlace video??
  • interlace video??
    Posted by Johnsabbath D’urzo on June 13, 2008 at 2:10 pm
    i have a video file that i’m buring to dvd. i rendered this file using upper filed and another render using lower field and anther render no filed… the video is still studders a bit during fast movement on the screan. how can i fix this. the file is 854×480 and i’m using After Effects, Compressor, and I also have Final Cut Studio Pro.
    Rafael Amador replied 18 years, 3 months ago 2 Members · 3 Replies
  • Rafael Amador
    June 13, 2008 at 3:03 pm
    854×480 is not a standard size for MPG-2. You won’t be able to toast a DVD like that.
    With your footage, make sure that FC is interpreting properly the Field Dominance in the Browser.
    Cheers,
    rafael
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Johnsabbath D’urzo
    June 13, 2008 at 3:18 pm
    i did a test with 854×480 and burned it to DVD with DVD studio pro and it works the footage looks a little interlaced how do i fix that?
  • Rafael Amador
    June 14, 2008 at 3:48 am
    Yes. DVDSTP convert it in a 720×480. But you have no control of this process.
    You don’t know where the interlacing problem come from.
    I recommend you export from FC a standard NTSC movie and watch it in an interlaced monitor.
    Is the only way to make sure that the rendering have been properly done and to avoid surprises when printing the DVD.
    You have use a size (854×480) that is OK for Photoshop, because is based in Square pixels.
    The 854×480 Square pixels movie have the correct aspect, but in the end must be converted in a 720×480 DV NTSC Anamorphic pixels movie. You must avoid this conversion. Is like adding an extra rendering in the end that won’t benefit your movie at all.
    Make your graphics in PH (854×480) and bring them to any AE composition or FC sequence with 720×480 DV Anamorphic. They will fit.
    In the end you will get a standard NTSC Anamorphic movie that only needs to be transcoded to MPG-2.
    JVC DTV-17″
