Interlace problem? Final video is not as crisp as in FCP sequence
I need your help to see if I created a problem for myself:
(First some backstory)
When I was trying to export my FCP project to compressor, the project continually failed. After many attempts to trouble shoot that, I gave up. I decided to go a different route. I decided to export the timeline to Quicktime (with the intention of dropping that file into a new project and sending that file to compressor). When sending it to Quicktime, I received error messages at inconsistent times during the export. In an attempt to isolate the problem/problem clip(s), I decided to create mini-Quicktime files of about 30 seconds (using default settings) and replace the original files in my timeline (even exchange) with the Quicktime files. After doing that, I tried exporting the timeline to Quicktime and it worked. I had a movie. I took that file and pulled it into a new project and successfully compressed it (120min Best quality).The problem is, when we screen the movie on a projector (via DVD), you can see the resolution lines (interlaced?). This is most obvious when text is on the screen. Font edges aren’t crisp. (But it looks fine on my monitor)
After years in the making, I want the best exhibition file as possible. I know enough about FCP to get me into trouble. Did I royally mess-up at one of these steps (or multiple times)? Or is this a compressor or DVD issue? I’ve seen the same problem with other films at festivals, so I know this issue isn’t unique to me. Help?!
SPECS:
Timeline:
HD 1440×1080
Video rate: 29.97I did notice now when I clicked on sequence setting that the compressor setting is HDV1080i60. Quality 100%.
(and yes, I tried applying the deinterlace filter on the sequence and it didn’t fix things)
Thank you in advance for your help,
Robert
