Activity Forums AJA Video Systems Interlace Issue
  • Interlace Issue
    Posted by Sheldon Pilot on December 2, 2005 at 11:34 pm
    Hi there:
    We are using a Kona LH with a Quad G5 2.5 10.4.2 and FCP 5.0.3. For analogue capture, we are using a Beta SP PVW 2800 to capture footage. We seem to have an interlace issue when we view the captured QT’s within QT Player. Within the FCP viewer and on a CRT there is no interlace issue. After creating a sequence which has the captured Beta SP footage and some titles and moving graphics we write to a QT uncompressed 8 bit QT which when viewed in the QT player still has the interlace issue especially with any movement within the Beta SP footage or the graphics. Again when we view the QT or the sequence on a CRT monitor there is no interlace issue.
    When we use the QT in Sorenson Squeeze 4.1 or Compressor, the interlace issue becomes more predominant due to the compression codecs we are using.
    My question to the forum is: Is there any way to get rid of the interlace issue if our final use is a file that will not be played back on a CRT monitor? I’m aware that LCD & Plasma’s are progressive scan as compared to the CRT which is an interlace two fields monitor. We are using the de-interlace filter in FCP which is a band-aid fix. But it does diminish the quality of our final QT master and looks really bad on playbcak on a CRT monitor. We have spoken to Rudy at AJA who is going to pass this issue on to some engineers and we are also speaking with Blackmagic, Luke Malsen and Kristian, as the same issue is on our SP and HD cards on two separate systems.
    Any input would be appreciated.
    Sheldon Pilot
    Sr. Producer/Project Manager
    AVHb2b Communications/Ogilvy
    Toronto, Canada
    Gary Adcock replied 20 years, 9 months ago 3 Members · 5 Replies
  • Rick Sebeck
    December 3, 2005 at 1:25 am
    There is a setting in Sorenson to de-interlace. Go to the filters tab and play with the different settings. “None” usually works good for me. I also crop the edges to TV safe (really helps when providing client approval) and adjust the black level.
    As for the interlacing… I have commented on this before, and everyone agreed thats just “how it is” I really notice it when I take those clips into AE to composite them. If change the scale and/or rotation it turns into a striped mess. I am forced to de-interlace clips before I composite with them. I’d love to hear what you find out from AJA about this.
  • Gary Adcock
    December 3, 2005 at 5:11 pm
    [Sheldon Pilot] “My question to the forum is: Is there any way to get rid of the interlace issue if our final use is a file that will not be played back on a CRT monitor?”
    Sorry but that is a fact of life with field based content, it is also the best reason to shoot progressive frames for non NTSC delivery. Your best bet is to edit your project as normal then run it thru the Nattress standards conversion as the last stage prior encoding for a DVD.
    NOTE: some networks will not allow anything other than a “hardware conversion” for broadcast transmission use but for a DVD release like you discussed using graeme’s filters works great.
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
  • Sheldon Pilot
    December 3, 2005 at 10:11 pm
    Hi Rick & Gary:
    Thanks for the reply. I was expecting this answer as my Sr. Editor and I have searched high and low and we are unable to find any solutions. It’s interesting that DV does not have this issue do to the 8:1 compression within. I wish there was a setting on the card(s) that could convert the captured clip to “p” instead of bringing it in as an interlaced file when using analogue Beta SP. It sure would make things easier when the final file needs to stay within a digital progressive scan world like the desktop monitors of our corporate clients. I will try the suggestion within Sorenson that you recommended.
    Thanks again,
    Sheldon
  • Sheldon Pilot
    December 3, 2005 at 11:29 pm
    Hi Rick, Gary et al:
    The filters feature within Sorenson Squeeze 4.1 is brilliant. I’ve made some custom filters with de-interlace, noise reduction, contrast, cropping, etc and I am happy with the results. Still think AJA and Blackmagic should look at what AVID does to solve the interlace issue with their systems when analogue Beta SP footage, which is normally an interlace format, is captured into their systems. I’m sure AJA and Blackmagic could learn a couple of things that would not require a post effect filter to be place over mastered QT’s in third party applications like Sorenson or FCP. Would still like to see my graphics and motion footage to be clean as opposed to a de-interlace filter. Oh well, for the time being, it’s better than where I started.
    Best,
    Sheldon Pilot
    Toronto, Canada
  • Gary Adcock
    December 4, 2005 at 2:18 am
    [Sheldon Pilot] “I’m sure AJA and Blackmagic could learn a couple of things that would not require a post effect filter to be place over mastered QT’s in third party applications like Sorenson or FCP.”
    remember Sheldon that these companies are making video products and in their world interlace is not really an issue as the final output for content is meant to be played out to a TV that interlaces everything. ( not too many Pal or NTSC progressive displays for consumers)
    As more and more people move into HD however this will become more and more an issue as most production in HD is not shot as interlaced any more – almost all is being shot so that it conforms to the progressive standard (even if it needs to be shown as interlaced at some point.)
    gary
    Gary Adcock
    Studio37
    Chicago, IL USA
