Activity Forums Avid Media Composer Interlace > 24P, Photoshop file gets weird
  • Interlace > 24P, Photoshop file gets weird
    Posted by Geoff Adams on October 23, 2006 at 9:29 pm
    Photoshop file of scanned grid paper to be used as background for animation. File is 720x 480 @ 72. Imported into AVID and placed in timeline for resizing in 24P project. Grid lines that look nice and even in orginal file get uneven and inconsistently thick/thin – horizontal lines only, verticals look fine. Is there a way to prepare a file in Photoshop to be imported to the AVID to avoid this de-interlacing artifact?
    thanks!
    Michael Phillips replied 19 years, 11 months ago 2 Members · 1 Reply
  • Michael Phillips
    October 24, 2006 at 1:59 pm
    You will get 2:3 interlace artifacts when going out to NTSC – This is especially noticeable on horizontal lines – try making them a little thicker if you can – softening the edges can also help. You can also try a very small amount of Gaussian blur as well.
    anything 24fps
