Activity › Forums › Maxon Cinema 4D › interface problem
  • interface problem
    Posted by Anthony Smith on August 26, 2009 at 4:09 pm
    Ok, I am really new at cinema 4d. in fact I have just started to learn it within the last 2 weeks. So far things are going pretty good but I have a small problem. when I installed the program, everything was perfect but starting about 2 days ago, whenever I launch cinema 4g, the program starts without any grid lines in the front, side or top view. Without these lines it will be a little hard for me to model anything. The last thing I remember doing was learning how to set a blueprint and make it transparent so I can trace over it. Could this be the problem? is there anyway to reset the program back to its default setting as if it were the first time opening it?
    Anthony Smith replied 17 years, 1 month ago 3 Members · 6 Replies
  • Tim Shetz
    August 26, 2009 at 5:38 pm
    Hi Anthohy –
    Depending on what you did, you can use the top icon on the left command palette and select the Standard Layout.
    Tim
  • Tim Shetz
    August 26, 2009 at 5:40 pm
    You might also want to check the Filter menu in each of the views. See if you’ve turned off GRID or any other items. If you pull down and select all, it should turn everything back on.
    Tim
  • Anthony Smith
    August 26, 2009 at 9:09 pm
    yea, i have tried both and nothing seems to work. any other ideas as to what could cause the grids to go away? i know for sure the last thing i did before this happened was to try a walk through to trace blueprints for buildings useing the grids.
  • Tim Shetz
    August 26, 2009 at 9:45 pm
    Without knowing exactly what that entails, I really can’t say what you might have done to turn the grids off.
    If you could supply more info, I might be better able to help.
    Thanks.
    Tim
  • Adam Trachtenberg
    August 27, 2009 at 4:54 am
    I can’t think what it might be other than the grid filter. If all else fails, try trashing your prefs directory. If you want to try that, go to editor>preferences and click the open folder button at the bottom of the dialogue. Then move or rename the prefs directory.
  • Anthony Smith
    August 27, 2009 at 5:44 am
    thanks, changing the name in the prefs really did the job. hope i dont make what ever mistake that was i made again. ^^
