Activity › Forums › Blackmagic Design › Intensity workflow – please clarify
  • Intensity workflow – please clarify
    Posted by Mike Cohen on March 7, 2008 at 1:43 am
    I have an Intensity Pro card, not yet installed.
    The Blackmagic website talks a lot about monitoring but not so much about getting your project back out to tape.
    Can someone please clarify the following:
    1. Assuming you capture via HDMI from a HDV camera or deck, to one of the non-HDV Blackmagic codecs. You then edit your project, using the Intensity’s HDMI output for monitoring on a HD monitor.
    When the project is finished, and I want to go back to an HDV master tape, do I need to export the project as HDV, or do I play out via component and record in real-time to HDV (not sure my deck allows this)
    Assuming I want to make a SD DV master, do I set the Intensity to output SD and record to tape.
    Likewise I assume I can export to any other format.
    Mike Cohen
    Mike Cohen replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
