Activity › Forums › Blackmagic Design › Intensity Quality in SD Live Acquisition
  • Intensity Quality in SD Live Acquisition
    Posted by Dan Asselin on August 31, 2011 at 2:10 am
    I have recently begun recording seminars and interviews with some quality SD cameras and a small portable PC. Always looking for extra quality I was wondering if acquiring an Intensity Pro would give me an edge over the firewire method I am using. Thanks for your time.
    Paolo Castellano replied 15 years, 1 month ago 2 Members · 5 Replies
  • Paolo Castellano
    August 31, 2011 at 2:49 pm
    Hello Dan,
    assuming that you are capturing from Firewire into DV format, using an Intensity Pro you could improve quality capturing from HDMI or YUV (no composite or Y/C) using a better codec (4:2:2 color sampling and higher data rate).
    Best Regards,
    Paolo.Castellano@ivs.it
    http://www.ivsEdits.com
    “Post Fata Resurgo”
  • Dan Asselin
    August 31, 2011 at 4:26 pm
    Thanks.
    Does that mean that I wouldn’t be able to achieve any improvement if I am bringing the signal in from S-Video or Composite?
    Regards;
    Dan
  • Paolo Castellano
    August 31, 2011 at 6:30 pm
    You’re right, Composite bandwidth is very limited (it is very difficult if not impossible to separate Luma and Chroma without loosing a lot of quality), S-Video is better, but not better than Firewire.
    Best Regards,
    Paolo
    “Post Fata Resurgo”
  • Dan Asselin
    August 31, 2011 at 6:34 pm
    Thanks a bunch that’s what I needed to know. I very much appreciate your time. Dan
  • Paolo Castellano
    September 1, 2011 at 9:01 am
    🙂 You’re welcome!
    “Post Fata Resurgo”
