Activity Forums Blackmagic Design Intensity Pro+Premiere Pro CS4+Cineform+Color Finesse?
  • Intensity Pro+Premiere Pro CS4+Cineform+Color Finesse?
    Posted by Mikael Couderc on August 29, 2009 at 8:33 am
    A few questions about The Intensity Pro (any info would be helpful):
    -Inside PPCS4, does it work with a Cineform Codec in a Matrox preset? (I know Prospect HD doesn’t support it yet, just interested in Codec support)
    -Inside PPCS4, using Color Finesse Plug in in Full UI, can I get the card to output a YUV through HDMI, Real Time?
    -Anything I should know about potential problems with this setup (PC Core i7 940, Windows 7 X64, PremiereProCS4, Cineform, Color Finesse)
    -Is there a better/more compatable BMD card for my requirements?
    Any input appreciated! Thanx and good day…
    Deleted User replied 17 years ago 2 Members · 1 Reply
  • Deleted User
    August 29, 2009 at 3:15 pm
    Hello,
    Inside PPCS4, does it work with a Cineform Codec in a Matrox preset? (I know Prospect HD doesn’t support it yet, just interested in Codec support).
    It only works with a Blackmagic preset output of your timeline.
    Not tried this, however component HD and SD out I can preview with After Effects CS3 from Blackmagic preset and using the Eclipse card. Don’t know if HDMI is supported, I can’t see why not?
    For the Cineform capture/playback it would be an AJA card like the Xena LHe, Lhi, 2k.
    I been reading on DVINFO on the Cineform forum that support for Blackmagic cardss with timeline monitoring should be avaialble at some stage for cs4 once the real-time engine has been intergrated into cs4, then once thats working then Cineform will be looking at the Blackmagic timeline playback.
    Leo
