Activity › Forums › Blackmagic Design › Intensity Pro with Premiere Pro CS5
  • Intensity Pro with Premiere Pro CS5
    Posted by Jim Scott on January 4, 2011 at 5:09 pm
    I have read the manuals but can find no way to output video from Premiere Pro CS5 to my external HD monitor via Intensity Pro as I can with Final Cut and After Effects. If anyone knows how I would greatly appreciate the steps to set it up or a reference to where I can access this information.
    Tony Harris replied 15 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • Danny Hays
    January 4, 2011 at 11:13 pm
    I’ve done it before with my Shuttle, can’t remember off the top of my head and I’m not at that computer. Let me check tonight and I’ll post it here.
  • Danny Hays
    January 5, 2011 at 7:45 am
    I swear I did this before but I cant get it to work tonight. Instructions say set “Edit/Preferences/Player settings/Blackmagic but it’s not working for me now. If I figure it out, I’ll post it. Sorry Jim.
  • Jim Scott
    January 5, 2011 at 5:01 pm
    Thanks for trying Danny.
  • Jim Scott
    January 6, 2011 at 12:30 am
    I had’nt properly selected the Blackmagic presets when setting up a new project. Once I did that the external video works fine.
    Thanks again.
  • Danny Hays
    January 7, 2011 at 12:03 am
    I knew I had it working before. glad you figured it out. Danny Hays
  • Tony Harris
    January 11, 2011 at 9:31 pm
    Could you share your project settings with me?
    I can only get video out of the Intensity Pro from the source monitor but not from the timeline program monitor even though I have selected the Black Magic card as the player in Premiere CS5’s preferences.
  • Jim Scott
    January 13, 2011 at 10:23 pm
    When you open a new project or make a new sequence you must select a Blackmagic preset from the “Available Preset” menu in the “Sequence Presets.” Until I did that I couldn’t get external video output. I think you will need to make a new sequence (File – New – Sequence) and choose a Blackmagic preset. Then drag your footage into that new sequence and you should see it on your external monitor.
    Hope this helps.
  • Tony Harris
    January 15, 2011 at 9:37 pm
    Thank you so much. I finally got it to work from both the source and program timeline windows.
    The weird thing is, HDV 1440×1080 will display no problem from the source window but not from the timeline. I created a new sequence using the BlackMagic presets and now video from the timeline window will show up on the output monitor as well.
    Thanks for your help.
