Activity Forums Blackmagic Design intensity pro with parallels
  • intensity pro with parallels
    Posted by Gerard Weemhoff on December 17, 2008 at 10:38 pm
    Hi
    for HD broadcasting to mogulus I needed to install window’s XP on my Mac Pro because On2 or Flash media encoder [https://www.adobe.com/products/flashmediaserver/flashmediaencoder/ is unfortunatly only available for windows. I used parralels to realize this. I installed the Intensity Pro correctly OSX and XP but The problem I have now is that I can’t configure the Intensity Pro in the configuration: I can’t set the capture or output device, these options are disabled.
    anyone a suggestion or solution?
    Thanks Gerard
    Joshua Helling replied 17 years, 9 months ago 2 Members · 1 Reply
  • Joshua Helling
    December 17, 2008 at 11:06 pm
    I am not 100% sure about this, but I don’t think Parallels will let you access hardware in XP mode. I believe this is because it is simply XP running over OSX.
    I am pretty sure you need to use bootcamp to do that.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
