Activity › Forums › Blackmagic Design › Intensity Pro usb port
Posted by Camilo Candia on November 18, 2009 at 8:11 pmHi.
The Intensity Pro on the back comes with a USB port.
That serves this port usb????…
Thanks…Camilo..
Joshua Helling replied 16 years, 9 months ago 3 Members · 5 Replies -
Camilo Candia
November 19, 2009 at 1:27 pmIf, I know the hdmi ports.
The Intensity Pro has a USB port that is inside the pc, Installed in the electrical circuit card.
For serving?????…
Thanks… -
Brian Louis
November 19, 2009 at 10:25 pmWhen you said the back I thought you were refering to the I/O ports, the small port is probably a test port, someone from BM probably could comment.
Joshua Helling
November 24, 2009 at 1:21 amThis port is for internal programming and will not be used by the customer in most cases. This is how we program the board at the factory. It will not function when the board is installed in the computer.
Hope this clarifies.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
