Activity Forums Blackmagic Design Intensity Pro – to buy or not to buy?
  • Intensity Pro – to buy or not to buy?
    Posted by Alex Kuzelicki on June 13, 2007 at 10:05 am
    I’m thinking of taking some ‘online advice’ and buying this package – a Benq FP241W monitor and an Intensity Pro card. Apparently, I can then output via HDMI for a truly accurate view of my HD footage whilst editing.
    I’ve been doing a bit of research and, actually in this forum, I noticed that there might be an audio synch issue. As the monitor (I’m about to buy) doesn’t have audio, I’ll be hearing sound directly from my Mac-connected speakers.
    It’s a worry that I therefore might not be able to edit the sound and picture together accurately.
    So I guess my question is, “Is this really going to be an issue?” or is the problem an uncommon one.
    Currently, I have two computer monitors that I use to split up tools and viewing windows (in FCP and After Effects). Not sure how the audio/picture synch problem would play out eg. would it match up on my computer monitors but not on the HDMI one?
    If so, I guess I could live with that, as the HDMI monitor would be mainly for checking the image quality anyway.
    If someone could provide some guidance, before I buy myself into some trouble, that would be much appreciated.
    Thanks kindly,
    ALEX
    Adam Portnoy replied 19 years, 2 months ago 2 Members · 1 Reply
  • Adam Portnoy
    June 13, 2007 at 5:22 pm
    As long as the analog and HDMI outputs are in sync from the card, you just need to be able to hook up the analog audio output to your speakers through a mixer or switcher.
    When I had the Kona card, all of my system audio and sound output was through the card. I would assume you could do the same with the Intensity Pro but I don’t have one.
    – Adam
