Activity Forums Blackmagic Design Intensity Pro Recording From HD Cable Box
  • Intensity Pro Recording From HD Cable Box
    Posted by Eliot Goshman on November 9, 2009 at 7:27 pm
    I have a Scientific-Atlanta 8300HD cable tv box/PVR and I wanted to move some of the HD programs I’ve recorded to my PC using Intensity Pro.
    I successfully did a 53 minute capture from the box to the card using the component & audio inputs on the breakout cable. (Almost 50GB!!)
    I had setup the Intensity for MJPG and 1920X1280.
    I tried to play the footage in Adobe Premiere Elements 8 and the program consistently crashed while trying to conform the footage.
    I then tried it in Pinnacle Studio 14, and while it played fine on the timeline, when I tried to burn it to a DVD, the picture was all scrambled, no matter what video settings I tried.
    I then tried Cyberlink Video Producer 4 which couldn’t keep the 16X9 AR, so I ended up with a 4X3 burn and lots of little crawly artifacts in the video.
    Next, I tried Nero 9, and after a long time processing the file, it burned to DVD…with audio only & no video!
    Is there any more standard way I can copy HD programs from the cable box to the Intensity card, with better compatibility?
    Thanks.
    Eliot Goshman replied 16 years, 10 months ago 2 Members · 2 Replies
  • Joshua Helling
    November 10, 2009 at 7:56 pm
    I would recommend trying the uncompressed codec (in a short amount) to eliminate if this is a file decode issue. I have a feeling that these applications are not properly decoding MJPEG footage. We can isolate this by doing a short uncompressed test.
    Sounds like some of your other issues (aspect ratio and such) might be caused by improper settings. For example there is a big difference in encoding something letterbox and anamorphic. Anamorphic if not encode/decoded correctly will show up as 4×3 (stretched tall)
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Eliot Goshman
    November 10, 2009 at 8:10 pm
    Hi Joshua,
    I had checked all settings carefully…the 4:3 result was not stretched vertically, it looked like the sides had been clipped.
    I’ll try a short uncompressed section, though I don’t think my drives are fast enough.
    Eliot
