Activity Forums Blackmagic Design Intensity Pro Output
  • Intensity Pro Output
    Posted by Lee Schneider on January 30, 2010 at 4:06 pm
    I’ve been using my Intensity Pro to monitor HDV & SD out into 2 different monitors. When I’m monitoring an SD Anamorphic timeline in FCP, I need to have the intensity preferences & video output set to BM HD 1080i in order to see the video on my Sony PVM monitor with the correct aspect ratio. If I have the prefs set to off for down conversion, and have the video output (in FCP) set to BM NTSC 720×486 I get a good clean signal, but it’s non anamorphic. Does this sound right? When I check color bars they are slightly different when in HD or SD, so I don’t know if I can trust what I’m seeing.
    Any suggestions/input would be great since i still haven’t received a response from BlackMagic on my last problem. Thanks! Lee
    Tracy Peterson replied 16 years, 7 months ago 2 Members · 3 Replies
  • Tracy Peterson
    January 30, 2010 at 6:14 pm
    Well, NTSC and HD will have different color values. That’s normal.
    For the downconversion, are you setting your monitor to anamorphic (16:9) playback? Most monitors i’ve seen play NTSC at 4:3 as a default, it’s not your intensity card. NTSC has the same number of pixels in 4:3 or 16:9, so you need to tell the monitor to stretch it back to the aspect you are expecting.
    Tracy Peterson
    http://www.onetwomany.com
  • Lee Schneider
    January 30, 2010 at 7:40 pm
    Thank you! That did it… it turns out I needed to have the monitors under scan on for it to pick up the 16:9 aspect after I changed the setting. Looks much better, thanks again!
    Lee
  • Tracy Peterson
    January 30, 2010 at 8:20 pm
    You are welcome. Please rate my post positive. 🙂
    Tracy Peterson
