Activity Forums Blackmagic Design Intensity Pro flicker in 1080
  • Intensity Pro flicker in 1080
    Posted by Camilo Candia on November 5, 2009 at 11:26 am
    Hi.
    Urgently need your help.
    When I capture with my Intensity Pro 1080 interlaced video from my camera Panasonic hdc-sd1 have an annoying flicker. When capturing the same camera but SD everything ok. I set up Intensity Pro so that this will transform the video SD in HD 1080 and all ok, Capture is fluid.
    The problem could be in the data bus?. Not how to solve..
    Team:
    Pentium 4 3.06 GHZ
    2 gb RAM.
    Geeorce 8400 GS 512ddr2 pci-e
    Intel motherboard D101GGC
    Sata hard drives
    Thanks for the help..
    Camilo candia..
    Camilo Candia replied 16 years, 10 months ago 2 Members · 2 Replies
  • Joshua Helling
    November 10, 2009 at 8:03 pm
    When you are capturing HD…what codec are you using? Uncompressed or MJPEG? If you are doing uncompressed do you have them setup in a RAID0 configuration?
    Sounds like a data throughput issue.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Camilo Candia
    November 11, 2009 at 8:34 pm
    Thanks for answering.
    No, I'm not compressing the video signal. No configuration RAID.
    Flicker is present in "preview" the 1080i video signal. When recording the video signal the flickering effect is also present.
    I use sata drives without problems.
    May influence the speed of the hard drive in "preview" of the video signal?..
    If, As you say sounds like a data processing problem. But where?…
    Thanks…
    Camilo..
