Intensity Pro Firmware Update Issues
Hi guys,
I was given an Intensity Pro for Christmas and used it with great success in my old computer:
AMD Athlon II X2 64-Bit CPU
WinFast Motherboard (I’m unsure of the model)
Windows 7 Eternity (Ultimate) 32-bit OS
2GB DDR2 RAM
400W PSUWith this older computer I was able to record uncompressed non-HD footage perfectly, but I could only get around 10fps if I tried to record compressed 720p from my Xbox 360 (Component input).
Now I have upgraded my computer to a much more modern one:
AMD Phenom II X6 1090T Black Edition CPU
MSI 890FXA-GD70 Motherboard
Windows 7 Eternity (Ultimate) 64-Bit OS
4GB DDR3 1333MHz RAM
650W Alpine PSUI hoped that with the extra, faster RAM and the hexa-core processor I would be able to record compressed HD 720p footage (or uncompressed if possible) to my USB 3.0 External HDD (2 TB).
I installed the Intensity Pro in the PCIe 2.0 x1 slot on the motherboard and booted up my computer. I then installed the latest driver from the Blackmagic website (Desktop Video 8.0.1 at this time). The installation asked me to reboot my computer so I did so. When it had rebooted it asked to do a firmware update, so I clicked update.
Immediately all 6 cores shot to around 95% and the computer locked up. The mouse movement was incredibly jerky and the system clock slowed down. I left it running for about 20 minutes in the hope that something would happen, but when I came back it was still showing the progress bar of the firmware update window, and the system clock was 15 minutes behind the actual time.
At this point I held in the power button on the computer to kill it. After taking out the card and rebooting, the computer ran completely fine. I then tried the card in the x4 slot, and a x8 slot for good measure. All have the same issue with the firmware update process.
After trying the latest driver with the Intensity Pro in each of those 3 slots, I removed Desktop Video and tried installing the driver and software which came with the card itself (Intensity 3.9.1), hoping that this would mean there would be no need for a firmware update. Alas the firmware update window returned and froze the computer. Once again after removing the card, the computer runs fine.
I am at a loss as to what could be causing this issue, and would appreciate any help you could provide to try and resolve it.
Thanks in advance,
Jamie
