Activity Forums Blackmagic Design Intensity Pro and Premiere Pro CS5.5 – jerky playback even after Rendering…
  • Intensity Pro and Premiere Pro CS5.5 – jerky playback even after Rendering…
    Posted by Christian Schaefer on July 7, 2011 at 10:39 pm
    Hey 🙂
    I have a problem:
    I use a Intensity Pro with Adobe Premiere Pro CS5.5.
    And I playout the Timeline through HDMI to a Flat-TV…
    The problem is, it is not possible to playout my Timeline (1080i50) without the playback gets interuppted!!!
    After a few seconds the playback stopps…
    Even if I render the whole Workarea the playback stopps (if I use some particular Effects for example the 3D-Effect…)
    Some other Effects for example the Ultra Keyer will playback smoothly (after Rendering the timeline)…
    I don’t know what I do wrong….
    Can yomeone help me?
    ok, my PC is not the fastest
    Dual Core, 3 GB RAM, IWndows Vista 64bit
    But why the UltraKey is played out smooth after rendering and the 3D-Effect not?
    Joshua Helling replied 15 years, 1 month ago 2 Members · 2 Replies
  • Christian Schaefer
    July 7, 2011 at 10:52 pm
    oh I just found the solution self….
    I have made a 3D PiP Effect (with the 3D-Effect)…
    I have rendered the video and the playback always stops.
    Its because I have no background used (just transparent > black)…
    If I use a picture or Video as background the playback is smooth 😉
  • Joshua Helling
    July 14, 2011 at 6:06 pm
    Christian,
    Thanks for sharing this. At first I was thinking that you were dropping frames and was gonna ask about your hard drive setup, but this is very interesting. So if you have no video in a background (id assume your V1 is being used as the source of the pip) you are getting this problem?
    I’d be interested in getting a sample project that shows this so we can check and send this to engineering.
    If you’re so inclined you can email that to support-usa@blackmagic-design.com. Put ATTN: Joshua in the subject and reference this post. That way we can check and look into this a bit more.
    But really appreciate you posting your finding!
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
