Intensity Pro 720p analog capture problem
I hope someone can help me out.
I’m using WindowsXP sp2 on a 3.2 Ghz dual-core Pentium with 2GB RAM.
I have a Seagate SATA secondary HD for capturingI’m trying to capture 720p MJpeg in PremierePro CS3.
When I start to capture, it runs for 1-3 seconds then freezes until I stop the capture. If I check the “abort capture on dropped frames” box, it will tell me that frames were dropped and stop capturing by itself.I’ve also tried capturing to a USB drive and to the C drive with the same result. Oddly, the C drive will go 30-45 seconds before freezing.
It’s my understanding that the SATA drive should be fast enough to capture MJpeg, so I’m stumped.
Also, if I use the Media Express app I get a dropped frames warning and the audio either gets way out of sync as the capture goes on or sometimes it records the audio at roughly double speed.
Any suggestions would be greatly appreciated.
JimE
