Activity Forums Blackmagic Design Intensity Drivers desapearing
  • Intensity Drivers desapearing
    Posted by Mario Gonzalez on November 25, 2009 at 12:11 am
    I juts instaled the Intensisty card wtih 3.4 windos drivers, I can ouput to HD MONITOR with vegas I cant capture , and also the drivers keep disapearing and have to uninstal and reainstall to be able to ouput video to HD MONITOR again
    Has anubody this problem or similar
    my system
    AMD qud /7 gig, SATA driver, windows vista
    Any help would be apretiated very much.
    Mario Gonzalez
    Joshua Helling replied 16 years, 9 months ago 3 Members · 4 Replies
  • Brian Louis
    November 25, 2009 at 9:58 am
    Have you checked the Harddrive the apps are on for hardware errors you may have some flaky sectors
  • Joshua Helling
    November 30, 2009 at 6:30 pm
    Hrm….I doubt the drivers are actually getting removed, but it would seem as if the board is being “disabled” in the device manager.
    If this happens regularly it would suggest a couple of things. One that there is some sort of system issue, which might cause the board to become unrecognized. I would update the motherboard BIOS (from the mobo manufacturer) and Motherboard Chipset drivers (from the chipset manufacturer, e.g. Intel, AMD, nVidia) as well as the peripherals (for graphics card, sound board and HBA).
    See if that helps stabilize the system. If it is still a problem you could be dealing with a flakey board, but I am not completely convinced of that, as if the board were the problem it probably wouldn’t work while the drivers were showing up.
    So give that stuff a check and if that doesn’t do it, please let us know.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Mario Gonzalez
    December 2, 2009 at 3:32 pm
    Thank you for your response, the bio is up to date, I recheck the board and is seated well, reinstall the drivers 3.4 I think , well the latest and the drivers are not been removed anymore but I have ouput sometimes and sometimes not, the last 2 days just nothig the monitor is a Bravia and gets the HDMI signal but no video, I will try anothe monitor just in case and let you know
    Thank you
    M Gonzalez
  • Joshua Helling
    December 2, 2009 at 11:54 pm
    Thanks Mario,
    If you continue to have problems with another monitor (though we use many different Bravias and they should be fine) let us know. It is possible that we have to replace this board.
    Sincerely,
    Joshua
    Director of Support
