Activity Forums Apple Final Cut Pro Legacy “Intelligent” Rendering – Telling FCP to render only nec’y mat’l?
  • “Intelligent” Rendering – Telling FCP to render only nec’y mat’l?
    Posted by Jeff Gerst on March 18, 2010 at 3:56 pm
    I’ve noticed that FCP will render even layers that aren’t necessary – for example, if I have a greenscreen video on V2 on top of a background on V1, and I put an entirely new video on V3, it renders V2 & V1 (taking a long long time), even though they are not seen.
    I believe Avid knows it doesn’t need to render V2 & V1. Is there a way to tell FCP not to render what is not seen or not nec’y to render.
    My poor man’s solution is to delete unseen footage for a faster render, but looking for a more elegant/quicker solution.
    Thx!
    Jeff Gerst replied 16 years, 6 months ago 4 Members · 6 Replies
  • Andrew Kimery
    March 18, 2010 at 4:15 pm
    You can select a clip(s) in the timeline and hit, I think, control+b to turn the clips ‘off’. They’ll still be in the timeline but FCP won’t see them.
    -Andrew
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
  • Jeff Gerst
    March 18, 2010 at 4:38 pm
    Nice! Good tip.
    It would be great if FCP knew what to process, but that’s a good workaround.
    Thx
  • Alex Elkins
    March 18, 2010 at 5:28 pm
    Hi Jeff,
    To my knowledge FCP onto renders the visible layers. Are you sure you don’t have something amiss on your top layer’s settings? Maybe opacity set to 99%, or not completely centred etc that would allow some of the V1 & V2 comp to be visible.
    Alex Elkins
    Salad Daze Films – Freshly Tossed
    Read my blog!
  • Jeff Gerst
    March 18, 2010 at 5:51 pm
    No, I’m sure there’s nothing amiss. I did an A/B test with the footage there underneath and with it deleted, and it took about 5x as long to render the same passage with the footage on V1 & V2 there.
    Thx, Alex.
  • John Fishback
    March 19, 2010 at 6:27 pm
    In the Sequence Menu > Render All you can set what renders. You probably have Full checked. That means every time you start a render, fully rendered clips will be re-rendered. If you uncheck that, they won’t render. Be aware that some transitions may be wonky if they are not re-rendered full. You may see a “jump” just before and after the transition. Then you can select those wonky transitions in the timeline and go to the Sequence menu > Render Selection and only have Full checked. Then, just the selected transitions will render Full. Hope this helps.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Jeff Gerst
    March 23, 2010 at 2:54 pm
    OK thx –
    Still though, seems odd that deleting the footage makes the render a lot faster than leaving it in.
