Activity › Forums › Avid Media Composer › Intel CPU Only for Media Composer?
Posted by Ervin Tia on June 10, 2013 at 6:25 amHello,
Is anybody running MC on a non-Intel machine? I’m looking at a more economical AMD or something.
Here’s a sample component:
[ https://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=... ]
Comments, anyone? Thanks!
Ervz | Video Productions | WMC-AP, Philippines
https://vimeo.com/ervzman/videosErvin Tia replied 13 years, 3 months ago 4 Members · 7 Replies -
Ronen Pestes
June 10, 2013 at 1:51 pmYou should stay within the avid specs for performance and longer life of your machine.
If you build your own system better not build the lowest level. New software changes and development will require more computing power by all softwares (avid, adobe etc.)
Also, make sure you can upgrade components if needed.
I build a Pc in 2008, it is still running and was good for using Avid for about 5 years.
Ronen
Ervin Tia
June 10, 2013 at 2:07 pmThanks Ronen. So you’re saying AMD is not good?
https://vimeo.com/ervzman/videos -
John Pale
June 10, 2013 at 2:24 pmAvid doesn’t test AMD. Who knows what it will do?
He’s saying its best to use what Avid recommends, as Avid is a very demanding application on your hardware. -
Ervin Tia
June 10, 2013 at 3:49 pm -
Ricardo Marty
June 10, 2013 at 10:42 pmOver at the avid.com forum some are running MC on amd system with no problems. but if you need to call avid support you wont get any help.
Ricardo
Ervin Tia
June 11, 2013 at 4:20 amok, that’s good news! Thanks!
