Activity Forums Adobe After Effects instanced comp driven by expression
  • instanced comp driven by expression
    Posted by Nicolas Elsig on May 31, 2012 at 10:37 pm
    Hello,
    I’m working on a weather forecast test and I’m trying to figure out if it’s possible to create a comp (pictoComp) with all my pictos animations layered. And then put pictoComp in each cityComp and load dynamicaly the good weather picto by an expression. Without duplicating my pictoComp x times by the number of city comps.
    It would be like an instanced pictoComp that would display a different layer for each cityComp.
    is it possible to do it by expressions ?
    thanks a lot for your tips
    Nicolas Elsig replied 14 years, 3 months ago 1 Member · 2 Replies
  • Nicolas Elsig
    June 2, 2012 at 7:02 am
    Thank you Dave,
    for “Dynamic” I was thinking I could have just one comp A with different images in it . Put it in different comps B1, B2, B3, .. and what I wanted is to have A react differently when used in B1, B2, B3… etc…
    But I ended in using images directly in B1, B2, B3, … and playing with an expression to display the good image with an external data file.
    for sure “Dynamic” was the wrong term …. as everyday I will render the project for the current day forecast with the data provided by the meteorologist
  • Nicolas Elsig
    June 4, 2012 at 4:02 pm
    yes I know live weather forecast solutions are available, but it’s for a small local TV, and those solutions cost thousands and thousands dollars. So plan B… we are working on something with a predefined animation rendered from maya and overlayed weather data is rendered in after effects via an external file.
    Actually they work with still images they receive everyday and place it in Vegas with a voice over.
