Activity Forums Adobe Premiere Pro installing premier pro 2
  • installing premier pro 2
    Posted by Griz13 on March 26, 2006 at 11:39 pm
    I’ve been trying to install premier pro 2.
    I started a thread earlier, but it was never resolved.
    I already have 1.5 installed, and as I understand it, 2 is a parrallel install, not an over install.
    I have transferred the install files to my hard drive.
    It’s actually an ISO image mounted on a virtual drive.
    I did this, because it was recommended that I transfer the files from the install dvd to my hard drive. I tried to just copy the files, but for one reason or another, I kept getting error messages when I did that.
    Now, when I try to install, I select English, I see a brief flash of “preparing to install”, then nothing.
    Any help would be greatly appreciated.
    Gargoyle13 replied 20 years, 2 months ago 3 Members · 2 Replies
  • Mike Velte
    March 27, 2006 at 12:16 pm
    Got to suspect a bad disc or faulty DVD reader. Try copying the files from the DVD to the hard drive on another PC and then Contact Adobe support for replacement.
  • Gargoyle13
    June 21, 2006 at 2:59 pm
    I should’ve posted this sooner, but the problem has been solved.
    There was nothing wrong with my DVD or my reader.
    As it turns out, the installation of Premiere Pro 2 is VERY susceptible to conflicting with other software on your pc.
    Long story short… I ended up having to pretty much re-install my OS, thereby wiping the slate clean, as it were.
    As soon as I was dealing with just Premiere Pro 2, it took off and installed like a champ.
    It was a fairly tedious process, but well worth the effort.
    And I lived happily ever after!
