Activity Forums VEGAS Pro Installing plugins (Mercalli)
  • Installing plugins (Mercalli)
    Posted by Paul Gregory on February 19, 2010 at 6:48 am
    I’m trying to reinstall Marcalli plug in by newly updated PC which is running Windows 7, 64 bit & I am having problems. Partially because I have so seldom used plug in & but also because I’m having problems with Windows 7 whereby I don’t know where its putting things.
    I assume that the Prodad files should end up in Vegas’s plug in folder but where it is on my PC I don’t know. I clicked on the winzip file the plug is in & it opens OK. It opens & suggests that it should go under programs Prodad. I click OK. Should I be changing the install location at his time to Sony’s plug in folder, FX folder etc.
    Once I open Vegas & put a clip on the time line & then select the FX icon from the clip Mercalli is not listed. How do I fix this?
    Thanks in advance
    Paul Gregory replied 16 years, 6 months ago 2 Members · 2 Replies
  • Theo Van laar
    February 19, 2010 at 10:36 am
    Wheb you install Mercalli, it is better to let the installer decide where to install. Then everything will work fine.
    And you know that Mercalli will only work under 32-bits Vegas 9 pro and not Vegas pro 64-bit? Probably that’s your problem.
    Theo
  • Paul Gregory
    February 20, 2010 at 1:52 am
    I had seen on the Prodad site that the requirements for its use included Windows 7 32 & 64 bit versions. Its only further down the page does it say that the Sony version is 32 bit only. Hopefully they will produce an appropriate version soon.
    Thanks in advance
