Activity › Forums › Avid Media Composer › installing magic bullet
Posted by Rap on September 8, 2006 at 6:00 amI don
Michael Thomson replied 20 years ago 2 Members · 1 Reply -
1 Reply
Michael Thomson
September 11, 2006 at 12:23 pmHi
The effects should be look suite, misfire, and de-artifacter. The 2.0 you refer to is the name of the magic bullet suite which is Editors V2.0.
Once installed these should be saved in the AVX Plug-in folder, and within the AVID these should be in the Effect Pallete (Ctrl + 8, or tools>effect pallete).
Your post didn’t specify which AVID system you are running but Magic Bullet requires a system running AVX 1.5 so if you don’t have a compatible system then you can’t use it.
Hope that helps if not then try the manufacturers site for support:
https://www.redgiantsoftware.com
