Activity › Forums › Blackmagic Design › Installing HP scanner G4050 kills Decklink drivers!
  • Installing HP scanner G4050 kills Decklink drivers!
    Posted by Igor Babic on March 7, 2007 at 3:52 pm
    Do not install HP scanner g4050 on Decklink system. After this instalation I have lost DL output from PPro2 and something dont alow DL drivers to be installed again(instalation is canceled in the middle of it). I have uninstall HP and DL software/drivers and try to install DL again but with no success. Only way to instal DL drivers is to “steal” BlackmagicDesign installation dir before DL instaler erase it on cancelation and manualy point your system where your drivers are, and manualy move install dir to program files.
    Does any body have similar expirience?
    Igor Babic replied 19 years, 7 months ago 1 Member · 1 Reply
  • Igor Babic
    March 8, 2007 at 1:45 pm
    I found that in regedit I cant delete some Decklink instances, that is probably why instalation aborts.
    Kristian, can you please help?
