Activity › Forums › Apple Final Cut Pro Legacy › Installed Studio 3 with FCP 6.0 already on mac and FCP 7 will not open?
  • Installed Studio 3 with FCP 6.0 already on mac and FCP 7 will not open?
    Posted by Richard Pengelly on May 19, 2010 at 10:00 pm
    Hi All,
    I recently installed Studio 3 on my mac book pro and FCP 7 will not open? It begins to open goes through its paces on the opening window and then just stops with the first window still open. I did have Studio 2 on there from before and FCP 6 still opens. Did I make an error when Installing? It was not an upgrade version I was using. Should I delete all the Studio 2 apps first? Do I need to upgrade the older versions first?
    Funkin it up Old School
    Michael Sacci replied 16 years, 4 months ago 3 Members · 2 Replies
  • David Roth weiss
    May 19, 2010 at 10:17 pm
    [Richard Pengelly] “Should I delete all the Studio 2 apps first? “
    Yes, download FCS Remover from https://www.DigitalRebellion.com and use it to remove all traces FCS 2 & 3. Then run fix permissions, then reinstall only FCS 3, and type in your old serial number when requested.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Michael Sacci
    May 19, 2010 at 10:25 pm
    Sounds like the install didn’t go through. While you can install over apps, you shouldn’t. When ever possible you should wide the HD, do a fresh install of everything. But understand that is often very hard to do. I would always recommend a total uninstall of FCS before any new install (or upgrade) this is not something you can do manually, you need and app. Link below to a free app (check out their other stuff, a must have for any user)
    https://www.digitalrebellion.com/fcs_remover.htm
    there are tons of post on the best practices from installing/upgrading, either Shane Ross or David Weiss has the best instructions to date if you want to go looking.
