Activity › Forums › Apple Final Cut Pro Legacy › installed latest quicktime now FCP won’t load
  • installed latest quicktime now FCP won’t load
    Posted by Latisha Willis on January 29, 2008 at 8:27 pm
    Hello all,
    I just updated Quicktime and now I’m getting the following:
    The application final cut pro hd quit unexpectedly
    I’m using FCP 4.5 on a powerbook g4.
    Any fixes? Please be detailed.
    Paul Escandon replied 18 years, 8 months ago 4 Members · 5 Replies
  • Paul Escandon
    January 29, 2008 at 8:34 pm
    Hmm.. did you upgrade to Quicktime 7.4? If so, that’s causing a lot of problems for a lot of people – so I’m not totally suprised.
    First, give trashing your preferences a try. Delete the pref file in User > Library > Preferences > Final Cut Pro User Data.
    When you relaunch and it still crashes – I’d say think about downgrading to Quicktime 7.3 (this is assuming you are now using Quicktime 7.4). Instructions for that can be found here: https://www.paulescandon.com/blog/?p=39
    I hope one of these methods work for you.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    oremusproductions.com | blog
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media – JPCU
    MacPro Quad-core XEON
    8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
    2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD
  • Walter Biscardi
    January 29, 2008 at 8:42 pm
    I would probably not be running Quicktime 7 at all with FCP 4.5 unless that was running at the same time FCP 4.5 was still the most recent version.
    QT 7.4 is causing all kinds of havoc with the current FCP, as has been very well documented in this forum, so I would suspect that is your main cause. Step back to an older version of Quicktime.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Colin Mcquillan
    January 29, 2008 at 9:03 pm
    A few of our machines are still running 4.5. A few months back some joker ran software update on them bringing QT to 7.2 i believe. The computers FCP performance slowed to a near halt. The computers were rendered near useless the lag was so bad. once we figured out the problem, we had to wipe them all clean for a fresh install to get things back to normal.
    From what I understand QT 7.x was never made to support FCP 4.5. 7.0 and 7.1 work ok, but beyond that first you will see performance issues, and it seems now perhaps a FCP total shutdown.
    Ours are back to QT 6.5 with FCP 4.5 and running great again.
    These days the administrative password is kept secret (as it should always have been in any multi-user setting)
    Colin McQuillan
    Vancouver BC
    MacPro Octo 3.2 6gig
    Dual 23″ ACD
    2TB G-Speed eS
    MBP 2.4 4gig
    Lacie Quadra 500gig
  • Latisha Willis
    January 29, 2008 at 9:39 pm
    Paul,
    Thank you so much. It worked. I really hope Apple responds by warning users of the potential for complete disruption of work flow associated with this problem.
    Thanks again
    Latisha
  • Paul Escandon
    January 29, 2008 at 9:41 pm
    Glad I could help! :]
