Installed both 64-bit and 32-bit and Both won’t Open Now
After using 64-bit Sony Vegas for quite some time now, I decided that I wanted to use plug-ins that aren’t available to the 64-bit program. After reading on here that you are able to run both, I installed 32-bit Sony Vegas. Keep in mind my computer is 64-bit and is very powerful. Now I am running into the issue where both programs will not open. Wen I click on Sony Vegas to open, it starts loading, then immediately stops. I’m not sure how to fix it as I ran it as Administator.
