Activity Forums Avid Media Composer Install AMC 2.6.6 onto laptop freeze on Initialise Audio
  • Install AMC 2.6.6 onto laptop freeze on Initialise Audio
    Posted by Alex Bond on December 8, 2010 at 4:08 pm
    Hi all,
    I managed to install AMC 2.8.1 onto a HP laptop with windows XP SP3 but I needed to retrograde it to AMC 2.6.6
    After much wrangling and deleting any evidence of 2.8.1 on the machine, I reinstalled 2.6.6 and it still believes there is a newer version of Avid in place which I need to delete – I’ve had to ignore this for now as I can’t see anything else to delete..so it continued to install, reboot etc.
    But when I load AMC 2.6.6 it reaches the stage of Initialising Audio and freezes – any ideas? Is it the audio or is that coincidence? Are there bits of the old version left that need to go?
    Is the Service Pack too high? Unlikely as it worked with 2.8.1
    Any help gratefully received, cheers.
    Alex Bond replied 15 years, 8 months ago 2 Members · 4 Replies
  • Michael Phillips
    December 8, 2010 at 9:02 pm
    I ran into a problem when initializing audio, and it really ended up being a graphics card firmware issue. Check the version you have and see if there is an updated version or not.
    Michael
    Michael Phillips
  • Alex Bond
    December 8, 2010 at 11:05 pm
    Cheers Michael,
    I’ll have a look – the bugger is it all worked fine with 2.8.1!
    A.
  • Alex Bond
    December 14, 2010 at 11:00 am
    Updated the firmware, graphics card is Geforce 7400 and works fine with 2.8.1 – 2.6.6 still crashes, any other ideas?
    Cheers
    A.
  • Alex Bond
    December 14, 2010 at 12:32 pm
    I’ve reverted back to 2.8.1, reinstalled it but have the same error- the laptop was fine before I tried any of this, does that add any more information?
