Activity Forums Adobe After Effects Insight on how can I reproduce effects seen on a video!
  • John Cuevas
    June 21, 2013 at 8:21 pm
    I assume you mean the layering/text treatments, but a couple of notes first. One the photos aare all well done/and might be roto’d(but most likely were just shot with the people against a black background). Also in the video, the video was produced for an extremely wide screen..maybe 4:1. Couple of things to keep in mind if you are trying to recreate this look.
    I made a comp that you can take that recreates the video(the bottom layer is the original video if you want to take a look). Mainly this is done using a series of layers that are using the text as a track matte or inverted track matte.
    Take a look at what I made and see if you can work it out. 6171_promointrofolder.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
