Activity Forums VEGAS Pro Inserting muzzle shots
  • Steve Rhoden
    June 27, 2008 at 9:24 am
    You are welcome..just remember to download the trial of sony vegas
    platinum first and give it a whirl and some tests.
    Steve Rhoden
    TNX EFFECTS STUDIOS.
  • Rob James
    June 27, 2008 at 8:39 pm
    Jesse, Fuddam’s detailed description is bang on, and Steve’s advice about Particle Illusions and Detonation Films are both excellent! I’ve had great success with both. But you must get Particle Illusions it’s unreal, you can even have muzzle shots, with shells flying out of the chamber (with or without smoke). Hard to top that!! All you need is a toy gun prop, and your movies will look incredible. Get all of the free Detonation Film stuff, blood explosions…………everything you’ll ever need, even rain and snow. Have fun…………if you can dream it, you can do it with those products………and Vegas of course.
    Rob,
    https://www.robjames.net/
  • Jesse Davenport
    June 27, 2008 at 10:33 pm
    So Action Movie Essentials would be the best way to go?
  • Steve Rhoden
    June 27, 2008 at 10:52 pm
    Well then yes…if you are working with limited budget.
    Steve Rhoden
  • Jesse Davenport
    June 28, 2008 at 7:51 am
    Is it possible to have muzzle flashes go in different directions? Or can they just go left to right?
  • Adam Rose esq.
    June 28, 2008 at 8:28 am
    use pan/crop to change size / rotation.
    can also right click the image inside pan/crop to flip the image horizontally etc
    can do the same with Track Motion if want to affect all clips on the track the same way, of course.
  • Jesse Davenport
    June 28, 2008 at 8:30 am
    Sorry if I seem really stupid about all of this, but this is my first time working with muzzle flashes. I downloaded the trial of Sony Vegas, and I downloaded a muzzle flash from Detonation Films, but it was in avi. and Vegas wouldn’t open it. Anyone know where I can get one real quick so I can test this all out?
  • Adam Rose esq.
    June 28, 2008 at 9:18 am
    um…………sounds like you’re doing something fundamentally wrong. Sounds like you’re trying to OPEN the avi, instead of simply dropping it on to the timeline, from either the Vegas explorer tab, or from a windows explorer window.
    detonation .avi’s are plain DV. nothing strange/unusual about them
  • Jesse Davenport
    June 30, 2008 at 6:59 am
    I’m having trouble. There’s a short clip of a muzzle flash in a black background with the flash in the middle. How am I supposed to work with that?
  • Adam Rose esq.
    June 30, 2008 at 7:52 am
    ok, I had a look. Because Detonation supply it as AVI, they don’t necessarily include an alpha channel (i.e. RGB vs RGB+). Anyway, going to have to use a different method.
    1) choose CHROMA KEYER from your video fx tab, and drop any of the presets on to the muzzle flash clip
    2) it will look strange but that’s because we have to tell vegas to lose anything black, not blue or red etc. Either set the RGB values each to 0, or drag the colour slider into black
    3) then drag the LOW THRESHOLD slider to the far right
    the text for Detonation Films will still be visible, so use the regular PAN/CROP tool of that clip to crop it out.
    oh, and once you’ve cropped it appropriately (with stretch to full screen turned off), you’ll have to use Track Motion to position it correctly
Page 2 of 2
