Inserting muzzle shots
Posted by Jesse Davenport on June 27, 2008 at 5:47 amHey everyone, I’m making a movie and before I buy Sony Vegas I wanted to know how you insert muzzle shots. I know of some programs that provide them, but I would like to know how, before I go and buy the program. Thanks for your time.
Adam Rose esq. replied 18 years, 1 month ago 4 Members · 20 Replies -
Adam Rose esq.
June 27, 2008 at 7:25 am1) buy the muzzle shots
2) drop them on the timeline on a new track above the video of the guns / shooting
3) right click the muzzle shot and choose PROPERTIES. Under the Media properties, change the Alpha Channel settings from NONE to either straight or premultiplied (you’ll have to find out which is suitable, based on the muzzle shots)
4) use Pan / Crop on the muzzleshots to size & position them correctly
Jesse Davenport
June 27, 2008 at 8:26 amSo if I get one of those programs that provide muzzle shots, I can just use those, right?
Also, does it matter which version of Vegas I get?
Steve Rhoden
June 27, 2008 at 8:31 amExactly as Adam said,
And may i suggest you can also buy “Particle illusion” to create
impressive and realistic muzzle shots along with explosions and
tons of other effects.
Or download some free ones at ‘detonationfilms.com
Vegas handles compositing these as good as any compositing application out there.Steve Rhoden
TNX EFFECTS STUDIOS. -
Steve Rhoden
June 27, 2008 at 8:33 amJust try and get the latest version of vegas.
Steve Rhoden
Jesse Davenport
June 27, 2008 at 8:43 amI can’t afford Vegas Pro, would Vegas Platinum Edition 8 be good? Also, which program would be the best to get? EffectsLab Pro and Action Movie Essentials are just two that I know about.
Adam Rose esq.
June 27, 2008 at 8:45 amwell, I for one don’t know how Vegas Studio handles alpha channel, so it might be different. Just download a trial version and you’ll be able to work it out.
try http://www.videocopilot.net too, for your muzzle flashes. They have a product called ACTION MOVIE ESSENTIALS from what I remember. muzzle flashes and blood and explosions etc. He uses them in After Effects, but same process in Vegas.
agreed that Detonation films has some good freebies.
Steve Rhoden
June 27, 2008 at 9:12 amSince you are working off a budget…..Go with video copilot action
movie essentials along with a few from detonationfilms.
No need to venture into ‘FXhome effects lab Pro’.You will experience various limitations using ‘vegas platinum editions’
if you want to really push the envelope in terms of providing
impressive shots.Steve Rhoden
Jesse Davenport
June 27, 2008 at 9:14 amWell this is actually a no-budget movie. Money is only coming from my paychecks right now. All I really want is for it to look realistic when the guns shoot. Will I still be able to do that?
Steve Rhoden
June 27, 2008 at 9:18 amWell then Jesse…You will definitely be able to do that and a bit more.
Steve Rhoden
Jesse Davenport
June 27, 2008 at 9:19 amThank you very much for all of your help. I feel a bit more confident now. Again, thank you.
