Activity Forums Adobe After Effects Expressions Inserting line breaks from Text File
  • Inserting line breaks from Text File
    Posted by Matt Miller on August 13, 2018 at 4:50 pm
    I have a script that uses an external text file to populate different copy points into an After Effects composition. The client I have is very specific about where the line breaks in the copy should be. I want to avoid having to go into each of the newly generated comps and manually insert the line breaks. Is there a way for me to add a special character into my text file that after effects can interpret as a line break through an expression?
    Thanks for the help!
    Matt Miller replied 8 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 13, 2018 at 11:01 pm
    You could do something like this to replace “*” characters with line breaks:
    value.replace(/\*/g,”\r”)
    Dan
  • Matt Miller
    August 14, 2018 at 4:43 pm
    Dan,
    Thanks for the quick reply. This is exactly what I needed, thanks for the help!
