Activity Forums VEGAS Pro Inserting an Audio Track
  • Inserting an Audio Track
    Posted by Stephen Mills on September 21, 2011 at 11:16 pm
    Vegas Pro 10
    By default…Noise Gate, EQ, and Compressor are the assigned effects whenever you insert an audio track.
    Is there a way to “permanently” assign/add another FX (for example reverb)as part of that FX list so i don’t have to keep adding it every time i want a new track?
    thanks
    Steve
    Stephen Mills replied 15 years ago 2 Members · 2 Replies
  • Jeff Schroeder
    September 21, 2011 at 11:53 pm
    Yes, get it all set up the way you want and right click on the track header and select “set default track properties”. (It works for video track too.)
    Jeff
    http://www.narrowroadmedia.com
  • Stephen Mills
    September 22, 2011 at 1:12 am
    thanks for the quick response.
    that certainly helps.
    I noticed Vegas wants to leave all the effects “checked” so if I set it up just the way I want(everything checked except 1 reverb unchecked) that track seems to want to stay checked as well when I insert a new track. Is there a way to prevent it?
