Activity Forums Adobe After Effects Inserting a camera into a cube in element 3d
  • Inserting a camera into a cube in element 3d
    Posted by Luis Garcia on May 8, 2018 at 8:34 am
    Hi! I would like to know if it is possible to put a camera into a cube (doing this in element 3d or another aplication). I would like to get a camera into the cube and put an image and that I can move the camera and see the images in the cube´s faces.
    Michael Szalapski replied 8 years, 3 months ago 4 Members · 5 Replies
  • Luis Garcia
    May 11, 2018 at 7:09 pm
    any idea please?
  • Cassius Marques
    May 11, 2018 at 8:09 pm
    If you check the material options to two-sides, you can look at it from the inside. You’ll probably have that option (or close to it) in any 3d ap. Either that or you flip the mesh’s normals.
    Cassius Marques
    http://www.zapfilmes.com
  • Richard Garabedain
    May 11, 2018 at 10:58 pm
    yes it is possible…putting an image on the inside of a cube you just hit the invert
  • Luis Garcia
    May 12, 2018 at 5:33 pm
    Thanks for your answer… How I could put the camera into the 3d cube?? I Am trying to do it but I can’t. I see the cube nearest and then I don’t see it because it is on the back of the camera…. O don’t know How to put into it to see the faces…. Thanks in avance
  • Michael Szalapski
    May 18, 2018 at 9:29 pm
    If you flip the cube’s normals you should be able to see it from the inside.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
