Activity Forums Apple Final Cut Pro Legacy Insert problem on playing out to a Digi Beta DVW- A500P
  • Insert problem on playing out to a Digi Beta DVW- A500P
    Posted by Video Editor on August 1, 2006 at 1:53 pm
    Hi Guys,
    We are new users to FCP, been working on it for under a month, and in the process of kicking our old Discreet edits out of the suites and replacing with new shiney FCP suites, and are having a small issue printing to tape, we are able to assemble a sequence no problem but as a test I have the placed two edit points in the sequence and made the clip black and white to look att how accurate the machine is for inserting a clip back into the tape.
    Upon Inserting the section of clip at the end of the play out it places a few frames of black over the sound and picture. Has anyone seen this before
    We have a G5 Quad2.5 with 4 gigs of Ram
    OSX 10.4.7
    FCP Studio 5.1.1
    Decklink Extreme software version 5.6.2
    Any assistance would be great
    Thanks in advance
    Darren*
    Video Editor replied 20 years, 1 month ago 4 Members · 4 Replies
  • Matt Callac
    August 1, 2006 at 3:09 pm
    The insert function works great. I use it all the time. Had to fix something in an intro for a Doc that was already mastered out to digi. I made my correction and just iserted in the edit to tape window. Frame Accurate and everything. You might want to check the mastering settings tab on the edit to tape window. It could be that it is defaulted to have a trailer for a certian amount of time. My guess is that is your problem.
    -mattyc
  • Jeremy Garchow
    August 1, 2006 at 4:41 pm
    You have to calculate your deck’s offset. I could explain it to you, but the manual does a decent job.
    Look at the FCP help PDF and page 332, “Calibrating Timecode Capture With Serial Device Control”
    Jeremy
  • Chris Jenkin
    August 2, 2006 at 12:57 am
    I’m an old edit user myself. I have an SX machine and have the same problems as you when it comes to inserting. If you close the sequence and just drag it in from the browser you will find that it should work. For some reason with assemble you can have the squence open and not have any problems. Still learning it myself.
  • Video Editor
    August 2, 2006 at 9:33 am
    THANKS GUYS,
    Chris that worked a treat, dragging to the source window and then inserting into the tape worked with no black at end of clip….. will have a loo at the callibration of the RS422 in the next few days,
    Thanks Guys, as allways the site works.
    Kindest Regards
    Darren Ali
