Activity › Forums › Adobe After Effects Expressions › Insert Line Break every X number of characters
Pete Menich replied 3 years, 10 months ago 10 Members · 22 Replies
Filip Vandueren
March 5, 2021 at 7:07 pm -
Matt Welton
September 17, 2021 at 1:07 amI’ve recently used this expression for a “textbox” .mogrt I’m making, but realized that if the inputted text has any return characters in it (i.e. manual line breaks) then the text in the subsequent paragraphs start getting line breaks in unusual places — as if the character count function gets thrown off somehow.
There also appears to be a “space” character that’s placed in the very beginning of the text that doesn’t exist in the text itself.
Does anyone have any ideas on how to remedy? The code is (unfortunately) a little outside of my ability, so I’m not sure how to troubleshoot it.
Matt Welton
September 17, 2021 at 3:25 pmFor context, here is the expression I’m using.
txt = value;
n = effect("Height & Width")("Slider");
outStr = "";
newLine = ""
splt = txt.split(" ")
//convertBreak = thisComp.layer("Body Content").text.sourceText.replace(/"\r"/g,"§");
//convertBreak = thisComp.layer("Body Content").text.sourceText.split("\r").join("§");
for (i = 0; i < splt.length; i++){
if ((newLine + " " + splt[i]).length > n){
if (outStr != "") outStr += "\n";
outStr += newLine;
newLine = splt[i];
}else{
newLine += " " + splt[i];
if (newLine != ""){
outStr += newLine;
outStr;
//REconvertBreak = thisComp.layer("Body Content").text.sourceText.replace("§",/"\r"/g);
//ReconvertBreak = thisComp.layer("Body Content").text.sourceText.split("§").join("\r");You’ll notice some code is commented out — these were my (failed) attempts to find/replace carriage returns with a symbol, then run the code that determines where line breaks should go, then restore the symbols to carriage returns again.
I also tried replacing \r with \n in the original code to see if that’d resolve whatever conflict was occurring, but that had no effect either.
Matt Welton
September 21, 2021 at 5:22 pmDan, do you think what I’m trying to do above is possible?
Thomas Frenkel
October 25, 2022 at 12:40 pmHi Dan,
is there a way to make this respect manually input line breaks? So that everytime I do a custom linebreak myself, i is reset to 0. That would be a dream.
Thomas
Yevhen Chak
November 6, 2022 at 1:25 pmSuper script. If I transfer the text to a new line manually, then on the second line the script continues to count characters and the transfer to a new line will be done earlier. How to make the script work on the new magpie first? Dan, thank you so much
Pete Menich
November 20, 2022 at 2:24 pmI’ve been trying something similar by hacking the original expression in this thread to get a subtitle to add a line break if the width of the text object goes above a certain length.
This seems to be working…
txt = thisComp.layer("Captions").text.sourceText;
dist = thisComp.layer("Captions").sourceRectAtTime().width;
Wguide = thisComp.layer("width guide").effect("Slider Control")("Slider")
len = txt.length;
if (dist > Wguide){
n = len / 2;
}else{
n = len;
outStr = "";
newLine = ""
if (outStr != "") outStr += "\r";
outStr += newLine;
newLine = splt[i];
}else{
if (newLine != "") newLine += " ";
newLine += splt[i];
if (newLine != ""){
outStr += newLine;
outStr;Except sometimes it splits the text over 3 lines when 2 will do – any suggestions?
Dan Ebberts
November 20, 2022 at 7:02 pmDo you just need to split it into 2 pieces if it’s too long? If so, see if this works for you:
txt = thisComp.layer("Captions").text.sourceText.value;
len = txt.length;
outStr = txt;
if (dist > Wguide){
if (len%2){
i = Math.floor(len/2);
j = i;
}else{
j = len/2;
i = j - 1;
while (i >= 0 && j < len){
if (txt[j] == " "){
outStr = txt.substr(0,j) + "\r" + txt.substr(j+1);
break;
if (txt[i] == " "){
outStr = txt.substr(0,i) + "\r" + txt.substr(i+1);
break;
i--;
j++;
outStr -
Pete Menich
November 21, 2022 at 10:39 amAs always, amazing! Works like a charm.
Is there a way that if after its been split over two lines and it’s still too long, that it could be split over 3, and then 4 lines etc etc
I’ve also been trying to use this script….
https://creativecow.net/forums/thread/paragraph-bouding-control/
but as my text is being driven by marker comments, it doesn’t work.
P
Filip Vandueren
November 21, 2022 at 1:39 pmThe “bound paragraph” methos should still work if the text’s driven by markers.
I think you’ll only need to change the first line of the sourceText parameter.But to be clear: that’s only if you absolutely need dynamic (moving) margins/width and reflowing.
For subtitles, why not use a regular box-text and let that do the wrapping ?
