Activity › Forums › Adobe After Effects Expressions › Paragraph bouding control
Posted by Jamel Ghabbara on March 4, 2021 at 11:33 amHi, i appreciate a lot your help guys.
i would like to ask if there is a way to use null objects the control paragraph bounding?
thank you so much
Jamel Ghabbara replied 5 years, 5 months ago 2 Members · 8 Replies -
Filip Vandueren
March 5, 2021 at 11:28 am -
Jamel Ghabbara
March 8, 2021 at 10:57 amsorry to bather you, but i had a small problem. the text is floating :/
Filip Vandueren
March 8, 2021 at 11:18 amIt appears it has left and right paragraph margins set up, or the text box was not created to be exactly 1000px wide maybe?
Jamel Ghabbara
March 8, 2021 at 11:40 am -
Jamel Ghabbara
March 8, 2021 at 11:48 amhere is what happen when i activate the expressions one by one, sorry to bather you again
Jamel Ghabbara
March 8, 2021 at 12:08 pmIT WORKED 😀 i was doing something wrong: i was applying SCALE and POSiTION expressions to “Transform Effect” and not the actual scale and position setting. than you sooo muchhh
