Activity Forums Blackmagic Design Input Mode Detection for Intensity Pro using DeckLink SDK
  • Input Mode Detection for Intensity Pro using DeckLink SDK
    Posted by Naveed Gazi on February 8, 2011 at 5:10 pm
    Hi all,
    As the subject suggests, I’m trying to automatically determine what display mode to choose based on the device connected to my Intensity Pro card via HDMI, using the DeckLink SDK. I went through the documentation and realized that Input Mode detection is not inherently supported for the Intensity Pro but I was wondering whether a work around is possible. I was thinking of looping through all the display mode indexes until I successfully received an appropriate frame. This would require grabbing a frame from the VideoInputFrameArrived() call back, and reinitializing all interfaces/pointers with the next display mode index if the call back function failed to return a frame.
    There are some problems with this approach, for instance attempting to stop the video/audio streams from the call back function will force the program to go into a bad state and it did, resulting in a segfault.
    Has anybody managed to find a work around to this limitation? Any advice/suggestions to my approach are more than welcome.
    Naveed
    Joshua Helling replied 15 years, 6 months ago 2 Members · 1 Reply
  • Joshua Helling
    February 16, 2011 at 6:42 pm
    Hello,
    Unfortunately this feature of the SDK only works on Decklink SDI, Decklink Optical fibre and Decklink Duo.
    We’ve gotten a number of requests for this feature to be added to other cards but if/when we are going to do that has yet to be decided.
    I hope that helps.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
