Activity › Forums › Apple Final Cut Pro Legacy › input 24fps audio out of synch
  • input 24fps audio out of synch
    Posted by David Tannenbaum on October 5, 2009 at 2:31 am
    On n a DVX-100 I recorded footage at 24fps audio at 48kHz. When I input this footage into FCP 5.04 with a preset DV NTSC 48kHz-24. (frame size720x480. Editing Timebase 24fps. Audio Settings 16bit 48kHz) the audio is off about 16-19 frames.
    What am I doing wrong?
    David
    Naiche Lujan replied 16 years, 12 months ago 2 Members · 1 Reply
  • Naiche Lujan
    October 6, 2009 at 4:55 pm
    I had a similar issue, not sure if it could be related, did you check the Frame Offset in System Settings under Playback Control. Once I set it to 0, all was fixed.
    Mine was only off by 4 frames though, sounds like this might be something else.
    Good Luck!
    Naiche
    Mac Pro
    Dual 2.8Ghz Quad-Core
    16GB RAM
    ATI Radeon 256MB
    320GB 7200rpm
    3TB 7200rpm Internal Software RAID0
    Blackmagic Studio Card (working good so far)
