Activity › Forums › Apple Final Cut Pro Legacy › Inporting DV4:3 clips look wide screen
  • Inporting DV4:3 clips look wide screen
    Posted by James Mulryan on August 11, 2006 at 8:20 pm
    I am using 5.1.1 and all of the sudden my DV footage that I batched digitized is coming into the viewer stretched to 16:9. My easy set up is for straight NTSC not anamorphic. I captured HD materia from a P2 card the other day, but changed my setup files back to straight DV NTSC prior to capture.
    Any suggestions.
    Thank you
    Jerry Hofmann replied 20 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 11, 2006 at 8:34 pm
    Look to see if the anamorphic checkbox is checked in the Browser column next to these clips… turn it off if it is.
    Jerry
