Activity Forums DaVinci Resolve Initial database installation problem because of a policy
  • Initial database installation problem because of a policy
    Posted by Mark Gin on July 8, 2012 at 3:49 pm
    I’m trying to install Resolve for couple of hours on a computer at my work place.
    The trouble is with the database:
    Because of the computer restriction, the postgresql cannot be configured with DaVinci as password – and it popups me an Windows error while installation:
    The password specified does not meet the local or domain policy. Check the minimum length, password complexity and password history requirements.
    I decided to install postgresql separately and setup the password to Aa12345.
    Now, when I start DaVinci I can create a new database. I fill there the label & DB name “unnamed”; user: postgres; Password: Aa12345.
    A new row is created, but with the following remark: Failed to initialize database unnamed:
    Failed to create baseline schema on database unnamed: ERROR: cannot drop language plpgsql because extension plpgsql requires it HINT: You can drop extension plpgsql instead.
    And I can’t select it.
    Can you please advise on this issue?
    BTW, I’m not so familiar with working with databases.
    Mark.
    Cristian Melone replied 14 years, 1 month ago 2 Members · 1 Reply
  • Cristian Melone
    July 17, 2012 at 10:10 pm
    I’ve resolved now an issue like yours, you need to just remove the plpgsql extension:
    * STEP 1
    Create the db from da vinci, doesn’t mind if you receive the error
    *STEP 2
    Close da Vinci and open PGSQL Admin III.
    Use localhost as address, user postgres and password, the password you used during the install.
    *STEP3:
    Double click on the db you created with Da vinci (in your case unamed I guess) and remove the extension:
    * STEP4:
    Open Da vinci, disconnect all database and click on connect (not create) and set the name of the db you just modified and your password.
    Then it should work. I think that issue is due to the way used in order to install the postgres via da vinci installer, and the standard install…
    I hope that works also for you.
    BTW: Leonardo Da Vinci was born in Italy, if you “resolve” the issue (ahah nice joke) you need to visit Italy, specially Florence!!
