Activity › Forums › Adobe After Effects › Infinite loop of text
  • Infinite loop of text
    Posted by Tom Balev on January 13, 2012 at 12:41 pm
    Hi guys. I’m trying to do a slider (with stock/share rates and currencies as you can see on most news TVs) but I have a problem animating an infinite loop. When I’m doing it with expression loopOut(“cycle”) then the text must pass over the whole screen to cycle again. Is it possible to define an Offset to this behavior ?
    John Cuevas replied 14 years, 8 months ago 2 Members · 1 Reply
  • John Cuevas
    January 13, 2012 at 5:20 pm
    Create your text in precomp and make sure your you have seamless edge. Basically a reasonable amount of space on either side. Now just add an ‘Distort > Offset’ effect to your text. Animate the offet or add an expression to offset position, drop it into your main comp and you should be good to go.
    Quick example project here:
    3535_stockticker.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
