Activity › Forums › Apple Final Cut Pro › Indulge a FCPX noob for a moment please
  • Indulge a FCPX noob for a moment please
    Posted by Daniel Frome on November 24, 2014 at 3:24 pm
    Let’s pretend I have two segments in a sequence, “SEG A” and “SEG B” which run one after another. I have a music track under SEG A, and a different music track under SEG B.
    If I cut a section of SEG A, The underlying music remains extended, and now overlaps the music from SEG B.
    Is there an easy way to automatically have the music under SEG A shorten, alongside any edits that I make to SEG A?
    Craig Alan replied 11 years, 10 months ago 6 Members · 5 Replies
  • Noah Kadner
    November 24, 2014 at 3:49 pm
    You could do this with a compound clip but that would make the sequence editing less flexible. I’d suggest lasso edits instead.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • John Davidson
    November 24, 2014 at 5:34 pm
    I use option+right bracket (or left, depending on your needs) constantly with things like this.
    John Davidson | President / Creative Director | Magic Feather Inc.
  • Bob Woodhead
    November 24, 2014 at 6:14 pm
    If you’re cutting from the end of Seg A, you could blade-all. Then select the end of Seg A, delete, and any connected clips on the end of A will go ‘poof’. 3 keystrokes. Shift-Cmd-B, C, Delete.
    PS – any connected clips that get bladed this way automatically re-connect to the 1st frame of the newly bladed Primary clip, which is why they go poof when primary is deleted.
  • Mark Smith
    November 24, 2014 at 11:39 pm
    This is a tricky question, no? you are cutting picture and expecting a music cut to be in the right place hen you make the picture cut?
  • Craig Alan
    November 25, 2014 at 3:53 am
    With snapping on and magnetic behavior, not hard to trim the attached audio to new edit point.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
