Activity Forums Adobe After Effects Expressions Independent keyframe velocity for each axis??
  • Independent keyframe velocity for each axis??
    Posted by Fridasongs on December 21, 2006 at 10:18 am
    Hi:
    I have a 3d layer which I am animating. When I alter the velocity of the keyframe, all “axis” (x,y,z) respond equally to it.
    What I want is for each axis to have it
    Mylenium replied 19 years, 9 months ago 3 Members · 2 Replies
  • Mark
    December 21, 2006 at 2:56 pm
    You could use expression to link each parameter to an expression controls effect (slider or whatever works best for you)….this will enable you to control each velocity individually….you could also do this via Nulls if you feel more comfortable with position values (Link each position attribute to it’s own Null….pos-x to pos-x on Null-1 etc…..)
    Hope this helps
    Mark
  • Mylenium
    December 21, 2006 at 4:09 pm
    Check the animation presets that come with AE. There is one to separate out X,Y,Z which will rig your layer with expressions just like Mark described.
    Mylenium
    [Pour Myl
