Activity › Forums › Adobe After Effects Expressions › Incrementing position of a layer using Trapcode Sound Keys
  • Incrementing position of a layer using Trapcode Sound Keys
    Posted by James Bazza on January 6, 2012 at 4:52 pm
    Hi there,
    Im trying to use the result of an output of sound keys to incrementally move the position of a layer..
    This is what I have tried, I cannot get the value to continually increment
    Thanks in advance for any help!
    SK = thisComp.layer("Soundkeys").effect("Sound Keys")("Output 1").valueAtTime(time+0.1)
    xPos = value[0] ;
    yPos = value[1] ;
    if (SK > 80){
    [xPos +20, yPos];
    }else{ [xPos , yPos ] ; }
    James Bazza replied 14 years, 8 months ago 3 Members · 5 Replies
  • Kevin Camp
    January 6, 2012 at 5:25 pm
    i can’t experiment with this now, but i think you should be able to incorporate dan’s beat counter expression:
    https://www.motionscript.com/design-guide/audio-count.html
    the beat counter expression is the second one on that page.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Dan Ebberts
    January 6, 2012 at 6:34 pm
    Another possibility is to set the Sound Keys Range Falloff control to “None (integrate)”. This causes the output value to continually increase in response to the audio.
    Dan
  • James Bazza
    January 8, 2012 at 10:20 am
    thanks for the replies…
    Ok I tried using a while loop but am still stumped… I cant get the position to keep on incrementing
    SK = thisComp.layer("Soundkeys").effect("Sound Keys")("Output 1").valueAtTime(time+0.1);
    xPos = value[0] ;
    yPos = value[1] ;
    frame = Math.round(time / thisComp.frameDuration);
    while (frame >= 0){
    t = frame * thisComp.frameDuration;
    if (SK > 80){
    xPos = xPos+20;
    }else {
    xPos = xPos;
    frame--
    [xPos, yPos]
  • Dan Ebberts
    January 8, 2012 at 4:39 pm
    Try this:
    SK = thisComp.layer("Soundkeys").effect("Sound Keys")("Output 1");
    x = 0;
    for (f = timeToFrames(time); f >= 0; f--){
    t = framesToTime(f);
    if (SK.valueAtTime(t) > 80) x += 20;
    value + [x,0]
    Dan
  • James Bazza
    January 8, 2012 at 5:08 pm
    ahh!! thanks so much, appreciate it. I see the mistakes I was making
    Cheers!
