Activity › Forums › Adobe Premiere Pro › Increasing/descreasing speed gradually
  • Increasing/descreasing speed gradually
    Posted by Kuda14 on May 30, 2007 at 4:54 am
    Hey everyone. I was wondering if it is possible to gradually slow/speed up the speed of a clip gradually through out the clip. I mean like the clip starts at 100% and ends at 50% speed, kind of like fading to 50% speed. Can anyone help me out! Thank you!!
    Cal Johnson replied 19 years, 3 months ago 2 Members · 1 Reply
  • Cal Johnson
    June 10, 2007 at 3:14 pm
    This is a good question. What you are talking about is called “Time Remapping”. At first, you’d think your request would be pretty straight forward, like “hey computer, just slow this clip down gradually”. But for the software, its a more complicated issue. You have to decide where frames are going to appear in your time-line, what portions are going to be slowed down or sped up, and what in or out points are going to be honored.
    Currently, time-remapping is available in After Effects. Its also coming out with Premiere Pro CS3. In the meantime if you want a cheat you could try creating a new sequence, put the clip you want to slow down in it, cut it up into sections, and then apply a different speed to each section, maybe even a dissolve from one section to the next. I’ve never done it because I have After Effects, so I don’t know how well that would work. Just another reason to upgrade to CS3!
    Cal
