Activity › Forums › Maxon Cinema 4D › Increase no. of batch renders
  • Increase no. of batch renders
    Posted by Olly Bea on May 29, 2008 at 4:31 pm
    Hey
    Can anyone help me?
    Is there a way to increase the number of batch render jobs (currently set at 10 jobs only) you can do at any one time?
    Any help would be gratefully received.
    Olly
    Randy Johnson replied 18 years, 3 months ago 2 Members · 1 Reply
  • Randy Johnson
    June 13, 2008 at 9:26 am
    I recently read about rendering direct from the console on the maxon site. If you start a render then start a new command you can start another…and repeat.
    This will not offset your animations though it just means you can render as many scenes as you want at the same time.
    As for adding in the batch render I have no idea.
    /randy
